Logging/fuel software
96talontso
300
Jul 12, 2011
Edmonds, Washington
Im having fuel cut problems and Im getting a walbro 190lph fuel pump and an afpr. But i dont have an eprom ecu or any logging/ fuel software. Ive heard of ecmlink but i want some opinions on what i should do for this cause i cant afford both, at this point its one or the other.
Link will save you a lot of headaches down the road. If you can afford that, get that I say. It's combination of logging and control are unsurpassed.
As for your fuel cut, how much boost are you running. And can you describe your "fuel cut" symptoms.
Im pushing close to 14 psi... And it is up to date... It feels like i hit a brick wall. What else would cause it other than the obvious boost leak
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
