lining up cams/resistance?
Sir, yes valves are going to need to be pressed open to line up your cam gears perfectly, hence the tension. I would never use "zip ties. Have a buddy hold the 17mm wrenches and you make sure the crank is in TDC. Also if you are using balance shafts make sure the oil pump and shafts are already in relation, Make sure the timing belt is loose on the tensioner side, before turning the idler pulley tightening the 14 mm bold in the center of the pulley and replacing the hydraulic tensioner!. Turn engine over 4 times until the #1piston is in the compression stroke and recheck the marks. Good luck!
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
