Injectors not lining up?
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
Purchased a fuel rail with a AFPR welded on the end of it. The guy said he got it in a trade, but never used himself. It's actually pretty cool how whoever did it, welded the gauge to the end.
My issue is, I can only get 1, maybe 2 of the injectors to actually sit properly in the manifold. They are sitting fine in the rail. I tried moving the rail and tightning etc, but no luck.
Is this rail just a lost cause, or is there something I can try to get all 4 seated properly? "They are just barely not lining up".
If it's a stock rail, you need the rail spacers to sit between the rail and the head and it helps to come down symmetrically with the rail and bolts lined up. I resolved my issue this way. If not try on the other one you had if no problem, then something is up with that rail.
Well, it's really not that they dont reach. It's more that they are off to the side a tad.
Can you actually move the injector so that it will go into the hole? Sometimes you have to move the a little bit in the rail to get them to go in.
:aha:try using your fingers, if its really not working then go back to the old rail and compare side by side,
You guy were talking about moving the actual injector? I did not think to try that, I was trying to press on the rail to drop them in place. When I get home from work I'll try that.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
