Line questions and intake line questions
GSXRolla
78
Apr 25, 2003
Edmonds, Washington
I'm soo close to getting this 6bolt swap running, and I'd like to start it up today. But I have a few questions that I'm clueless on.
1) There are 2 vacuum lines coming out from a selonoid underneath the coolant overflow tank. One has a T connection. Where do these connect up to?
2) There are two thick lines coming off the intake pipe (not the bov return). I know 1 of them connects to the valve cover... where does the longer, thicker one go?
3) Where does the think line from the bov connect?
Thanks... I think these lines are the only thing holding me back from starting this thing up, so anything that anybody can throw at me would be greatly appreciated. Thanks again!
Background info on the car: '95 Eclipse GSX
Found most of the answers.
1) They were from the Boost Control Solenoid and would connect to the stock T25. Because I'm not using the T25 anymore, and am using a boost controller,I can unplug the lines, and control the boost via the MBC. The BCS lines can be left unplugged.
2) Still don't know where the thicker one goes to... perhaps the evaporative canister? Don't know :(
3) BOV vacuum line connects to the intake manifold directly to the right of where the pcv valve connects.
If anyone has any insight into where # 2 connects, it would be appreciated.
