2 Vaccum line questions
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
Can anybody help me figure out where this port on the intake manifold goes?
Was also wondering if anybody had a pic of how the fuel pressure solenoid is supposed to connect, does it matter whitch side of the solenoid goes to whitch? 1 port is black the other brass colored.
Is it 1 from the manifold, to the solenoid, then from the solenoid to the BOV?
cant say for 100% sure but i think u answered your question, THAT is the line for either the BOV or fpr solenoid. im not infront of my car atm(and the engines out anyway) but i also think that the IM goes to the vac line on the passenger side of the solenoid, the other vac line from the solenoid goes obviously to the fpr.
correct me if im wrong. also, i think its possible to just run without the solenoid. i know it is when running an aftermarket afpr.
edit: just reread, you can t off the im and go to bov and fpr if you want but theres def 2 ports there anyway so u dont need to if you dont want
Solenoid is not needed but for stock I would keep it hooked up. That nipple is for the BOV, the FPR nipple is towards the drivers side of the manifold.
