Limitations of the 7CM housing
thilaksharma
310
12
Jul 3, 2006
Evo City, Asia
I searched but could not get any info on these
whats the limitations of the 7CM turbine housing
will it get choked ?
i have a 46trim or 50trim compressor side ( the compressor wheel measure 53-54mm)
7cm + evoIII turbine wheel at the rear
i did go on the dyno sometime ago ,
the power died at 6500rpm
would this be caused by the 7cm housing or is it because i run on stock cams
thank you
here are the pics of my turbo :D
http://img231.imageshack.us/img231/1656/04012008087640x480mc0.jpg
http://img295.imageshack.us/img295/8649/04012008086640x480dy8.jpg
http://img408.imageshack.us/img408/6591/04012008084640x480ig5.jpg
People have trapped high 120s-low 130s on TD05H wheels in 7cm housings, and well over 130 with TD06H wheels. A handful of Reds have gone faster but were most likely on 8cm housings. And yes, your cams and intake are killing your top end. Even with FP2s, my airflow flatlines just under 7k with a stock intake manifold, even with a big T3 hotside.
