Light Bulb Replacement #'s ??
Slipstream
539
10
Jun 8, 2004
Northern, California
Okay I have a few burned out bulbs and I'm looking for the replacement #'s.
HVAC bulb?
Cigarette Lighter Bulb?
Ignition Ring Bulb?
and that damn map light?
Thanks.
If I find the right #'s I'll let you know...I just put in an order for an 850 piece bulb set...worse case scenario a similar enough bulb will be found in that kit that will work. :rolleyes:
Thanks, I'll buy that for everything i listed...except the map lights...which use a festoon style bulb.
i got 194b's (B) for blue for my door lights the ones in the corners, the glove box, and my a/t selector, and 211b's for my map lights but for some reason they went red :mad: so i put the stock ones back in, as for the a/c switch, heater and the vent control, i found there 194's also, but can't figure out how to get them out :confused:
Theres only one HVAC bulb. you need to take out the vent trim right above the HVAC to get to it. you also need to remove the AC button to make it easier. then just get a small flashlight and find the bulb. its right behind the air temp knob (hot or cold) then just twist the bulb to the right i think and it will pop out.
Thanks!!! now just need to by some more bulb's hehe, thanks again, will give it a shot!!
