Black95TSIawd
- 2,620
- 411
- Jan 28, 2003
Dirty,
New Jersey
That is amazing news!! Put me down for a set!!Hey guys, I figured I'd pop in with a small update.
I've decided to build this around the Moog 2G replacement balljoint. They're well-built, easy to find, reasonably priced, and uniquely small enough to fit the application.
I've got all of the components drawn in CAD. I'm awaiting a quote from my CNC laser guy. But I could have a prototype arm ready to be used in as little as 3-4 weeks.
I don't have the whole arm modeled, but here's some of the basic components:Do you have any cad pics?
That bolted joint on the end is interesting. I assume it's to quickly swap out the ball joint? Or maybe for something else?
I didn't think of that. Expected something more inboard.I'm having a hard time picturing this.If slotting is a bad idea then the ball joint portion could alternatively be made with multiple versions, each with a different pair of hole locations for bolting into place, changing the offset and thus the caster. If that portion was simple enough the cost might not be so bad, just drilling the bolt holes in different positions relative to the ball joint. I picture like a ball joint cup welded to a flat strip of metal. Might be annoying at first to set up and test, but once done you're done. Caster typically isn't something you play with much once you get enough of it and make it even across the car.
Solidworks and eMachineshop's CAD. I've never done FEA, but I've been itching to learn it for years.Creo ? SW? looks familiar but having trouble figuring it out from your screens. Are you pretty solid with FEA?
just curious
These will be capable of being shorter or longer than the OE arm.
But I wonder if most guys are running these at the OE length or other?
I typically build these with the ability of being slightly shorter, but vastly longer. And I could certainly change that if need be.
I edited my last post. I had had a few vodka cranberries last night when I posted and I was accidently talking about the LCA's.
Thanks for the input, guys. It's going to be impossible to have the ability to be at the stock length and have 1" of adjustment. I'll be using 5/8" heims, and the general rule of thumb for thread engagement is 1.5x thread diameter. But they can be at a minimum of 1x. At .625" thread engagement, that leaves about .975" of thread that is not engaged. Minus the thickness of the jam nut (the thinnest one I have available is an aluminum one at .315" thick), that leaves us with only .660" of available length adjustment.
So the question is, where exactly should the range be? Stock to -.660"? Or -.340" to -1.00"? Or somewhere in between? I wonder if anyone would need or want to run these at the OE length?
I think what I'm going to do is build a trick adjustable jig, and I'll allow buyers to specify any changes to length. I could also relocate the balljoint for built-in caster. And they could be tweaked from there by adjusting he heims. Thoughts?
Yes. Send mine now. Extra rice for me.
