- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Precision Ball Bearing Turbo
Dejon 3” turbo Pipe
full 3” thermal cat back
2600 lb act clutch
greddy blow-off valve
greddy intercooler piping
K&N FIP kit air-filter
greddy profec A boost controller
60 mm greddy peak hold boost and EGT meter
HKS turbo timer
AEM wide band air/fuel
EVO III Exh manifold and O2 housing, ported
ARC - 2 ignition pack
60mm 1g throttle body
MOROSO Oil pan
Flex a lite Slim Fans
Fluidyne Radiator
Greddy Radiator Hoses
Prothane Bushing Kit on Motor mounts
- Mods-Engine
- balance shaft eliminator kit
6 bolt swap
ID 1300x injectors
E85 AEM Fuel pump
AEM fuel rail
6AN fuel hard line fm tank to rail
swirl polished valves
Wiseco pistons and eagle H - Beam rods
2g ported head and 3 angle valve job
blue printed and balanced crank and pistons
HKS metal head gasket
ARP head studs
Crower Springs and Titanium retainers
Greddy cam gears
Crower cams
Evo 3 IM
- Mods-EMS & Logging
- DSMlink V3
- Mods-Drivetrain
- Quaife LSD
Equal length Half shaft mod on FWD
- Mods-Handling
- Road Race Engineering strut tower bars, all 3
Eibach Pro lowering springs
Tokico Illumina 5 Way Adjustable Shocks
Evo 8 Enkei 17” wheels
ZE40 Matte Blue gunmetal 18x9
nitto nt555 235/45/r17
Stop Tech rotors and 4 piston calipers
SS Brake lines on all 4 corners
Energy Suspension Complete Bushing Kit
Camber Correction Kit on all corners
