lean when let off throttle
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
I am having a slight tuning issue whenever I let off the gas when I am driving on matter what rpm I let off at or how fast I am going my wideband goes all the way lean and will stay there until I give it more gas. When I am at idle though when the car is not moving the AFR is around 14.2-14.6. Fuel trims are adjusted good. The car holds idle good but the ISC position will not stay at or around 30 like it is supposed to. Its more like 60-70. I am using dsmlink with narrowband simulation with an autometer wideband. I also did the FIAV mod and still using a ISC sensor. Any ideas to why it is doing this would help. Also if i put it in neutral while driving the rpms stay at around 1500 until I let it idle for a few seconds then the idle drops back to 1000 where it should be.
Yes, when you let off the throttle. You will go full lean, because the ECU cuts fuel.
As for the idle rpm issue. Sounds like a bad IAC (ISC). Try disconnecting it, and driving.
Disconnect the plug, set your idle, and then drive it around.
The ISC could be bad and stuck some what open.
Thanks for the responses. I know that the car will go lean after you let off the gas but I always thought if you let off the gas while you are driving and you are cruising/under a load, while giving it no gas, the car should not be all the way lean. I figured it would be somewhere close to 14.7. I guess I'm wrong.
