Leaking Coolant when car shuts off
Bloody Panda
63
May 13, 2012
Homer Glen, Illinois
So I've noticed that my car leaks coolant out of the overflow when I shut it off. I was thinking that this might be a bad rad cap? Could that be the solution?
Pull the thermostat out ,, Some people with mods need a better rad or use high temp coolant .. Everyone thinks the faster you go the better, with out thinking about the cooling system :thumb: just my 2 cents
Edit , Pull the thermostat out , to check that its working (opening and closing)
Definitely leave the thermostat in. It's warming up so maybe your car is getting cooled a bit less. Thoroughly check over the entire system, make sure she's full of coolant and that the coolant looks good and clean.
Sorry guys , edited my post ..Meant pull it out to check it ..Boil some water and drop the t-stat in , watch for it to open
Yes try this. I've heard this is a great way to test it. Also, my buddy put a high performance aluminum rad in his subbie and it runs a looot cooler now. Make sure its double core.
If you changed the ECT sensor along with your old thermostat maybe one of them was bad and now with the new ones your system is working properly. If you don't see any signs of it overheating I wouldn't worry about it.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
