Leaking Coolant when car shuts off
Bloody Panda
63
May 13, 2012
Homer Glen, Illinois
So I've noticed that my car leaks coolant out of the overflow when I shut it off. I was thinking that this might be a bad rad cap? Could that be the solution?
Well I was planning on changing the coolant/flushing the rad but theres no point if im just going to lose some of it.
Also, what are some strong symptoms of a slightly bad head gasket, to the point where I should change it. If that makes sense.
Mine did the same thing, it turned out to be a radiator cap, do the cheapest first, a radiator cap with a safety pressure release is like 11 bucks. i got that solved all my over heating problems
start wit the basic cheap/free fixes.
It can even be the overflow tank itself, Rad cap, thermostat, bleed the system, flush the system,its needed for maintenance so suck it up LOL..
If it persists then do a leak down test and a compresion test, for the head gasket.
Mine did the exact same thing and it was the thermstat.
I'm going to replace the cap today and test the compression and then go for there. Ill give you updates after I do.
So today I did a compression test and changed the anti freeze/burped the system. For the compression test, from cylinders left to right, it read 150psi 130psi 95psi 130psi. Also, I noticed that the plug in the last cylinder was wet with oil. As far as changing the coolant went, the problem still occurs. Tomorrow I am going to get a new cap, if that doesnt work, then I am going to get a new thermostat. If none of this fixes the problem, what do suggest I try next? A new head gasket?
Mine is doing the same thing and still trying to figure it out. I've changed the thermostat and did the compression test today and got 170, 175, 170, 165. Starting to think its the hg but don't want to believe it. My car has 217000 miles on it.
I got a new radiator cap yesterday but my car is up on blocks replacing the front cvs. Once I get it on the ground, ill let you know if the problem still occurs.
If your compression numbers are solid and there is no evidence of coolant in the combustion chamber or oil or external leak then your headgasket SHOULD be good.
To the OP. Sounds like you need a rebuild.
To the thread hacker, check your cooling system.
Two things that should be replaced periodically is the radiator cap and the thermostat. When doing a timing belt job then replace the water pump. When doing a system restore use a good system cleaner to remove any corrosion/scale from the system to have a peak performing system.
Sorry I haven't responded in a while, but yes I did change the cap and that fixed the problem. But recentlyy rad cracked but I replaced it and all is well. Thanls for the help guys.
Where is your temp hand say at? Ive changed my cap, stat, and temp sensor. My hand is half way and doest overheat, but it use to not go that high. I dont know what else to check for. Guess I'll jack your thread since your all fixed up and Im having the exact same problem.
So what is your problem? That the temperature gauge stays in the middle where it should and it didn't do that before?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
