DSMPT
DSM Wiseman
- 3,461
- 3,306
- Jun 12, 2014
Japan / Mexico,
Arizona
The best would be to get another rod bearing set and drill straight in the right angle or send it to R&R and ask them to do it. But maybe adjusting the hole position may work, you should ask Mike at R&R for advice first, that would be the safest.I see. I did drill them out with a 3/16s drill bit. It's possible that it could be slightly off. I also know I did some test drills on my OEM bearings and it was MUCH much worse offset than the ACL bearings that are in there now.
So what might be your suggestion then? I don't necessarily trust any local shops around here to drill them for the dowel. Is there a good way to check if the bearings are drilled straight?
The pin hole is for oil jet on OEM rods, so OEM and ACL should have it in the same position. I think your case is what I said above. Maybe you accidentally changed the angle while you were drilling by holding it by hand. IIRC the angle was around 4~5 degree. I have done it by a hand drill but holding it by a bench vise and the tool I showed you in your another post.
