Kapok6
- 1,393
- 271
- Aug 10, 2004
Fort Worth,
Texas
I need some help here/have a question...
I believe the same question was asked here but never resolved:
http://www.dsmtuners.com/forums/newbie-forum/374656-koni-yellow-install-question.html
So I have read Vfaq about 10 times. I have my original (gr-2) housings disassembled and ready to go. Now, when I slide the Koni cartridge into the GR-2 housing, the bump located on the koni as referenced in the Vfaq catch on the inner lip of the housing.
However, this places the threaded bottom of the cartridge about and inch above the bottom of the housing, (again, as referenced in Vfaq).
So, my question is, since I don't want to ruin anything, do I thread the bolt in without the washer and such, as referenced in Vfaq to pull the cartridge further down? That would pull the protrusions past the lip in the housing. And If I am supposed to pull the cartridge down, how far do I go? Until the cartridge reaches bottom?
The instructions say to torque to 55ft lbs.
I guess what I am concerned about is that on one hand, the protrusions are supposed to be seated on the inner lip in the housing. Bat at the same time, vfaq is saying to thread the bolt to pull it past that lip in order to be able to thread the bolt with the washer(s).
Some advice would be much appreciated.
Regards,
-Ryan
Regards,
-Ryan
