Ludachris
Founder & Zookeeper
- 8,836
- 4,654
- Nov 12, 2001
Newcastle,
California
So I've cut up the casing and am test fitting the Koni insert into the old GR2 casing. The bottom of the Koni insert doesn't quite reach the bottom of the casing. In fact, it's enough of a distance that the bolt that comes with the Koni kit doesn't even come close to catching the threads. My options are to A. get longer bolts that will catch the threads, or B. cut the casing shorter.
If I buy longer bolts, it doesn't seem to me that the setup would be all that strong. It would seem stronger if I cut the casing and allowed the insert to sit at the bottom of the casing tightly. However, if I cut the casing shorter, I'm not sure what negative effects it will have.
Can anyone chime in on this?
