campos_racing
- 197
- 1
- Aug 10, 2011
Laredo,
Texas
Okay guys so after finally assembling the car after a year, i have a weird knock at the head, but, its only at about 800rpm or so that it does that. I would figure if it were a bent valve etc. the noise would not go away. Though it might be the lifters? If I am at about 3-5k rpm you can hear the cam real loud as if maybe the lifters were not working. Im out of suggestions and searched several threads and videos on youtube but nothing similar. I will try and get a video tomorrow since its my off, but though that somebody might have had this problem. Thanks
We just finished doing my friends timing and it had skipped a tooth after we finished so we had to redo it. Such a pain to do. You should change the oil and when you change it check if you have any metal shavings. Take off the oil pan also check in there. Might have spun a rod. Check the rods to see if they have any play and check the crank also. I had that problem also but it was crankwalk on my 7 bolt. Crank moved side to side :'(
