DSMReviver
- 1,134
- 80
- Mar 4, 2008
Little Rock,
Arkansas
I am looking to buy a new exhaust manifold. My stock one started to crack and time to upgrade to something a little better. Looking at Kinetic and Bullseye they are similar in design. I need an opinion or someone who have experience with these manifolds to give me the first look. Both of these manifolds i like about them is that they came with external wastgate ready tap into them. It allows you to run external gate in stock appearing manifolds with larger runners on the inside. I like this better then force performance manifold because of this...
I call both the Kinetic and Bullseye and got a little more details about their casting material. FYI, Bullseye still make their cast exhaust manifold but you can only get them through Bullseye.
Kinetic is made out of High Silicon Moly. These type of material-from research- is use from egr housing to exhaust manifolds. This is pretty common for exhaust manifolds casting because of its low cost.
Bullseye from other hands use stainless material in their exhaust manifold castings.
What grades of stainless steel they use i don't know.
What is the better casting from both of these manifolds? From talking to both companies, they seem to make these manifold for slowboy in the earlier years. They both claimed to have improved their designs...
