kiggly flexplate install question
blktalon3
Supporting VIP
548
79
Aug 30, 2006
Stanford, Kentucky
Trying to install a Kiggly flex plate, but had a question. On the crack theres an alignment pin but theres no hole on the flex plate for it . I've read through all the threads and no one mentions anything about it. Not sure what to do
The dowl is because that engine was for a manual trans. Pull the dowl and your good to go.
Yup.
When you are putting the Kiggly flexplate in measure up your bolts. If you are using stock Auto trans crank bolts they'll likely be too short. I used a set of shaved down manual trans flywheel bolts.
