Kiggly adapter question.
goodbuds
1,043
7
Nov 10, 2009
oceanside, California
I have read into this, but seems some what confusing. My question is do I need to acquire the small spacer that goes between the bolts and the adapter. Not the kiggly spacer but the oem one that comes from a auto 6 bolt engine. Again I'm talking about the small oem spacer with 6 holes and goers directly behind the bolts.
And if I need it were can I find one.
nobody knows?
From the factory there is one in front and one behind the flex plate I believe. In the Kiggly instructions, it only shows you putting one on top and the flex plate goes right up against the crank.
You can get them from JNZ tuning, that's where I got mine. Kiggly directions show 1 that goes on between the plate and bolts.
Also make sure you check clearance between the flex plate and rear main seal housing as well as the oil pan. I needed to clearance some of the pan as well just to give me a bit more comfort room.
