Kiggly manu-matic wiring question!
kp116
620
3
Mar 25, 2009
Janesville, Wisconsin
Can anyone tell me what the wiring colors are on the PRNDL that needs to be wired to the solenoid. From the pictures its a little hard to tell. I can see the 12v (blue), a solid yellow and a yellow with a orange tracer. The one I am not so sure about is the other one which looks to be yellow with a black tracer but when wired up to that wired all I have is 3rd gear. I see there is also a black with a white tracer and a black with a yellow tracer. I was wondering if I am on the wrong wire for that solenoid?
I just did mine a couple months ago and I remember having similar questions. I don't have my car to reference right in front of me but I'm almost positive you have it right. You use the yellow, yellow with red and the wire that's predominantly yellow with a black stripe. Same thing happened to me and I ended up not having a good enough 12v connection to the blue wire leading to the gear selector. I'll snap some pics of mine to be sure when I get home from work if you haven't fixed it by then.
This is how I did it, quick and simple. I made a harness using the Kiggly wiring schematic and I just tapped the wires in the gear selector plug like so:
Thanks for the help. I did have it right, what I had to do is actually take apart the valve body, clean it and it has been working ever sense. I guess a few other people have ran into this problem as well. I don't know if a plunger was sticking or what but it works now!
