Keep ac or ditch it?
dannigirl4g63
Jan 20, 2011
Spokane, Washington
Im building up my 90 tsi and while i was tearing everything out of the engine bay to prep it for paint I was trying to decide if I should put the AC back on or not. I rarely use it anyway and it would reduce the clutter but i'm not sure if it will be worth the risk of the defrost issues ill have in the winter. Any suggestions are wanted!
If you don't care much for creature comforts then do away with it. Especially in Washington, it's not like you have to put up with Florida's nasty humid heat. For defrosting, I just crack the windows, set the controls to recirculate, and only run about 1/2 heat or so. It doesn't work super fast, but still works.
Remove it. Like other have suggested it cleans up engine bay. Helps with more cooling. It increase's airflow through your fmic and radiator.
I need to recharge mine ASAP. Starting to get a little warm out. Never owned a car with working ac so once I get it charged I will be a very happy camper LOL
If its a matter of weight reduction then chuck it.
If its a matter of gas mileage just remember when the windows are down your killing gas mileage as well too.
Personally for my baby son and my girl I'm fixing mine and as a HVAC tech It just looks bad when ya don't fix the one in your car LOL.
I did away with mine. At times I really wish I had it LOL, especially since its getting pretty warm here lately. At the same time it's not my dd do if it's really hot I'll just jump in the dd and crank the ac. It does get rid of quite a bit of clutter though.
I think this is a more a matter of cost. You don't need AC to have your defrost work in the winter. To properly fix AC is one of the most costly fixes on a car. If the AC doesn't work right now it isn't as simple as just recharging especially since it is an R12 system. All the lines need to be flushed. A vacuum needs to be pulled on the system. Different compressor oil, new dryer, probably a new expansion valve, replace all the o-rings. There's no guarantee just replacing the o-rings will fix the leak that was in the system either. Could be a hole in the condenser or evaporator.
If you have a close friend that does AC work I'd have it done if you can get the parts and labor at cost or good guy price I'd have it done.
How would you flush the lines?
It's a nice comfort, and if I drove mine every day, I'd keep it. But I don't and I don't plan on driving it when it's warmer than 70-75, so I yanked mine. Not sure what the Pacific Northwest climate is like, but I'd imagine you should be able to get by without it.
Remember that the 1G units ran R-12 which is not forboten, but rare to find and very expensive now.
You'd have to do an extensive and expensive conversion to run the R-134 fluids.
I do the '60mph and windows down' AC usage after I yanked mine out when the compressor seized.
Here's some reading blurb on if any of you want to convert from R-12 to R-134A below:http://www.griffiths.com/achelp/achelp3.html
Friend of mind tried his own conversion-blew up the compressor since he didn't rid of the old mineral oil inside.
-DSM
If it's as hot over there as it is as over here then keep that mofo! By the time I get to work the back of my shirt is wet. But I have A/C it's just the leather seats that sit in the sun aren't fun though..
I live in ALaska, WA is pretty similar. I ditched the AC, shaves off about 40lbs and it's kinda of hard to get R12 now.. i think its R12?? haha
