What causes the AC Control Unit to keep failing?
Spades
273
4
Apr 29, 2007
Beaumont, California
Has anyone gone in depth to repair their AC control unit (ECU) and to find out what is causing them to fail? I had mine fail a few months ago and I just bought a good used one from someone else and it worked for about 20 minutes and failed again. Id like to find a schematic showing the pinouts of the unit so i can see what components are being driven by this control unit. And what does the adjustment screw control
Here is a pic of the control unit
Haven't repaired one but from the diagram I can see that if there was a short to ground in the green-orange wire, it would burn up its output transistor. Don't know what the adjustment screw controls - perhaps temp turn on value or temp hysteresis. Sorry but with images limited to 700 x 700 pixels it is a little blurry with all its detail. Pm me with your email address if you need a little clearer image.
Hmm, my AC control unit has a 12-pin & a 6-pin all combined into 1 harness but in the diagragm i see only 5 pins being used. PMing you with my address for that higher res version, I just printed it and it was this little 2.5 x 1.5 image :)
Is the "Fin Thermo Sensor" the same as the expansion valve? And if so, does it OUTPUT to the AC control so that the AC control can cut-off power to the compressor? Or is it the other way around in that the AC control sends a signal to open /close the expansion valve?
