jbl_5star
- 150
- 0
- Dec 14, 2009
Puyallup,
Washington
someone told me you can clean them yourself or lifetime warrenty or something is this true?
how do you clean them if its true?
Similar question, but I run a Vibrant Performance filter and does anyone know if I would be able to use a K&N kit on it to clean it up assuming it needs oiled?
Yes, the Vibrant elements clean and oil the same way as a K&N element. The K&N recharge kit will work on any cotton-gauze, oiled element.Similar question, but I run a Vibrant Performance filter and does anyone know if I would be able to use a K&N kit on it to clean it up assuming it needs oiled?
)That is a cleaner kit specifically for dry-type elements only. It's just a cleaning solution - no oil. And it's not cheaper that the correct kit either. K&N 99-5000 - K&N Recharger Filter Care Service Kits - Overview - SummitRacing.comThis is typically what I use on my K&N filters as it is roughly 7 dollars cheaper than the K&N stuff. AEM Induction Systems 21-110 - AEM Induction Dryflow Filter Cleaning Kits - Overview - SummitRacing.com
