Canadian_CD9A
Supporting Member
- 1,233
- 1,146
- Feb 10, 2012
Winnipeg,
MB, Canada
1). Any boost, vac, or exhaust leaks?
Yes - tiny TB leak, takes a few minutes to drop below 15 psi
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock coil
Wire brand and Age: Some JDM aftermarket, look good
Spark Plug brand, type and Gap: NGK BPR6ES ~0.30
5). Motor health (Compression Test)
Cylinder 1: 155
Cylinder 2: 160
Cylinder 3: 160
Cylinder 4: 160
6). Performed basic throttle body adjustments?
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
7). Compression ratio
Stock 2g (8.5:1)
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running): 12.6v
Car running: 14.0v
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.5
Injector Size (cc/min): FIC 650cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate LC1/XD16
Calibration Date: June 2015
13). Type of fuel
Type: Husky 94 Octane
Percent of Ethanol: 10%
14). Watched ECMlink how-to videos?
Yes
Hello, I just got my car running on ECMLink v3 Lite. It's a 1993 Mitsubishi Lancer Evolution, so basically a 7-bolt setup, I'm running without a MAF sensor on an Omni 4-bar and GM IAT using the "2003 Evo 8 GSR mod 1" map. Setup:
Powertrain:
-Forced Performance FP68HTA turbocharger
-Ported 7cm turbine housing & 34mm flapper valve
-Holset wastegate actuator
-Forced Performance Race Manifold
-Evo III o2 housing
-A'Pexi 2.5" downpipe
-High flow catalytic converter
-A'Pexi N1 catback exhaust
-Evo I intake manifold (stock, same as Evo III intake manifold)
-ARC Intercooler & piping
-HKS-RS Intake Pipe with big K&N filter
-HKS SSQV blow-off valve, recirculated
-Walbro 255lph fuel pump
-FIC 650cc fuel injectors
-Sard fuel pressure regulator
Boost creeps up to around 16 psi (set to 15 psi on a Blitz SBC i-D, gain was a bit high for the run though). It won't go much lower than 14 psi because of the wastegate spring. I do want to raise the boost as far as it will go without knocking, I have to get my FIC 1000cc injectors in first though because I kissed the 80% DC at 16 psi.
I think I have the basics dialed in pretty well, can anyone critique my 3rd gear pull? I'm not quite sure how to dial in the WOT, the how-to on SD tuning was a bit vague in this regard.
Yes
Yes
4). Ignition system
Cylinder 1: 155
Cylinder 2: 160
Cylinder 3: 160
Cylinder 4: 160
Idle Switch: Yes
Throttle Cable: Yes
TPS: Yes
BISS: Yes
Stock 2g (8.5:1)
No
No
Car running: 14.0v
13). Type of fuel
Yes
Powertrain:
-Evo III o2 housing
