Just Bought a GST For $500.00, Need Advise!
PrettyBoy23
44
Jul 8, 2011
El Mirage, Arizona
Hey guys, I just bought a 1991 GST for $500.00, you will not find a better deal than this anywhere else. Now you might be thinking, "I bet it's only the shell". Well thats where your wrong. The car has 100% exterior, 100% interior (Super Clean), and the motor and tranny are working 100%.
I will be the 3rd owner of this amaizing car, and the last guy didnt know anything about cars and never raced it. The car does have high miles, but he only owned it for about a year. The guy before him rebuilt the car 87k miles ago.
The car has 287k miles, and the guy sold it to be because he thought that the car had come to his end since it dies, and runs rough. After diagnosing it myself, I re-charged the battery to 100% and it doesnt seem to be the problem for the car dieing. It is the alternator that does not work anymore. The reason why the car is running rough is because the timing is off, needs new spark plug wires, and new injectors. Also maybe change all the fluids in the car.
<script src='http://imageshack.us/shareable/?i=frontiq.jpg&s=809&p=tl' type='text/javascript'></script><noscript>
</noscript>
<script src='http://imageshack.us/shareable/?i=rearme.jpg&s=8&p=tl' type='text/javascript'></script><noscript>
</noscript>
<script src='http://imageshack.us/shareable/?i=rear2w.jpg&s=69&p=tl' type='text/javascript'></script><noscript>
</noscript>
<script src='http://imageshack.us/shareable/?i=sidebc.jpg&s=35&p=tl' type='text/javascript'></script><noscript>
</noscript>
<script src='http://imageshack.us/shareable/?i=rimsv.jpg&s=695&p=tl' type='text/javascript'></script><noscript>
</noscript>
<script src='http://imageshack.us/shareable/?i=rearseats.jpg&s=803&p=tl' type='text/javascript'></script>
<script src='http://imageshack.us/shareable/?i=frontseats.jpg&s=121&p=tl' type='text/javascript'></script><noscript>
</noscript>
Mod's:
A/R .50 T4 Turbo
JDM Sport FMIC 3" Piping
Upgraded Turbo Manifold
External Wastegate
BOV
3" Straight Piped
Boost Controller
This my is my first time owning a DSM, yet alone a turbo car. I have been doing research ever since Ive bought the car and it seems that I have been learning fast. But I might need some help recognizing some of the parts. I have a plan for what I want to do with the car, I will explain this later.
BOV:
I tried doing some research on the BOV's, and tried finding out which one this is. I even looked all over it and it has no writing or anything. So does anyone know which bov this is? And is it any good?
<script src='http://imageshack.us/shareable/?i=bovs.jpg&s=707&p=tl' type='text/javascript'></script><noscript>
</noscript>
Boost Controller:
Does anyone know any info on this boost controller? I thought that a boost controller was electronic and went inside the car...LOL? Is this boost controller any good? How do you know what psi your turning it to? Kinda wierd.
<script src='http://imageshack.us/shareable/?i=boostcontroller.jpg&s=11&p=tl' type='text/javascript'></script><noscript>
External Wastegate:
If im not mistaking, this is an external wastegate right? I was just thinking about leaving this how it is. Maybe give it a good cleaning or so, but what do you guys think? Sh:hellyeah:ould I leave it like that, or should I get a wastegate?
<script src='http://imageshack.us/shareable/?i=externalwg.jpg&s=13&p=tl' type='text/javascript'></script><noscript>
FPR:
So I know that if your gonna push higher horsepower than stock, that you should upgrade the FPR. And since I do have T4 turbo and palan on pushing 350hp, i want to upgrade. But is this the stock FPR? looks like the stock one. Denso-1262.
<script src='http://imageshack.us/shareable/?i=fpr.jpg&s=856&p=tl' type='text/javascript'></script><noscript>
Injectors:
Ok so this is probably one of the stupidest things someone can do. I seen that these are not stock injectors. To have a T4 turbo you can probably get away with 550cc, but seriously. These are 240cc injectors, who would put anything lower than 550cc injectors if upgrading the turbo? I was thinking maybe get 660cc injectors. What do you guys think?
FMIC:
I have a JDM Sport Intercooler installed, are these good intercoolers? Ive tried looking for reviews but I guess none yet. Has anyone installed these on there cars? Should I change it out for a better one down the line? It has 3" piping.
<script src='http://imageshack.us/shareable/?i=intercoolerk.jpg&s=808&p=tl' type='text/javascript'></script><noscript>
That boost controller is junk and is probably causing you problems. It will only allow you to run wastegate pressures or LESS. It will not allow to you increase boost pressure beyond what the wastegate is set at. I would eliminate that boost controller temporarily by running a vaccuum line from the wastegate to the turbo outlet so you can run wastegate pressure until you get a boost controller that will actually control it.
i would make sure the timing is not off more then a tooth maybe too anything more and i bet u have a bent valve. but not a bad buy at all!!! did u drive it yet with the timing off supposedly??
