just bought a 92 gsx need help
madmax92gsx
Feb 23, 2010
crescent city, California
im new to dsms and turbo cars. i just bought a 92 gsx completely stock. the guy i bought it from said it just needed a new ecu and i got one but its still giving me problems. it idles funny like it doesn't want to keep running and white smoke shoots out the exhaust constantly. once i replaced the ecu it gave more power but after a couple blocks of driving it died and wont start back up, im not sure if its burning to much fuel or what. can anyone help me out?:confused:
we started up the car and it smokes and when i put my hand by the exhaust tip my hand gets wet with gas and smells like gas. i pulled the spark plugs there pitch black the smell like pure gas.
Running a non-turbo ECU in a turbo car will do that.
The ECU thinks the injectors are 240cc, turns them on for the couple of milliseconds it thinks it needs to, and winds up drowning in fuel because the 450cc injectors spray almost 100% more fuel that is needed.
Also you said you replaced that tee right?
Is it possible to put a straight piece of vaccume tube between the too main points?
Are you sure you don't have a vaccume/boost leak?
I'm half awake so it this don't make sence, sorry I try'd.
ya i put a strait piece and took off the tee.
steve i sent you a pm for the ecu's, i dont know if it went through cause my comp is kinda messed up so let me know if you got it.
