Just Boosted
240GTR
30
Sep 12, 2003
Yourtown, Montana
Ok we finished the full setup on our 1999 420A, and we have this little missing link peice thats supposed to fool the MAP sensor, a black box with a red and black wire, has anyone ever used this unit, if so, do you know how to hook it up ours came with no instructions? I think this is our main problem, the ecu keeps throwing up a tps low voltage code, and a map code, also when the car idles, you can tap the gas, and the vac will drop to -20, then creep back up to -10, and the car will barely run, keeps popping and backfiring won't boost at all.
Any ideas?
Thanks for all of the help
J.
Any ideas?
J.
http://home.bendcable.com/optimuspeterson/late fuel instrucitns.htm <--- go to step 8
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
