Just a question about injectors.
DSMLoverFromUA
115
May 23, 2003
Lodi, New Jersey
Are all the injectors are universal? Can you like take a civic injector and put it in a galant? Just weird thoughts are going thru my mind. What size are old school supras injectors and like rx-7 anyone know?
One more question. Is 1gen SMIC is begger then 2gen?
The fitment of injectors are basically the same except the electrical plug.
Also keep in mind on if the car they came from has and injector resistor or not. ( as far as if they will work on your car)
Don't forget "type" of injector.........
Depending on the year car they came from Honda used saturated and non-saturated (peak and hold) injectors. Roughly pre-OBD1 engines had peak and hold injectors, and OBD1 and newer engines had saturated injectors. CRX's and older Civics/Preludes have resistor boxes.......newer Civics and Integra do not have these.
~Saturated injectors - no inj resistor box used, generally smaller size injectors
~Peak and Hold injectors - a inj resistor box is NEEDED, generally larger size injectors
You should not mix them from engine to engine. Running a set of peak and hold injectors without a resistor box will possibly damage the ECM or injectors themselves. They will not respond correctly anyways.
So, you just confuse me but its ok. Maybe i should say this way, is there any other "old" vehicle that has bigger injectors then ours and could be used on our cars?
what about the 1gen SMIC?
Sorry....just wanted to make sure you had the info
What about EVO8 injectors? They are 560cc or something like that and can be found pretty cheaply/easily I have heard. I do not know what size the RX7 injectors are though.
FYI Honda injectors are 240cc at best though
evo8's are 580cc, much bigger than stock DSM turbo injectors...other than that, I haven't heard of many other DSM'ers messing with other cars injector
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
