jumpy tranny
tronno
73
Nov 3, 2005
hagerstown, Maryland
i just put in a sprung 4 puck racing clutch kit and when i go to put my car in reverse, it jumps like clutch is engaged.first gear is sorta hard to get into but it doesn't jump the tranny or anything.i bleed my clutch already.what do you guys think is going on.
should i adjust my clutch pedal.it engages near the top,before the clutch pedal is let out all the way.could it be my old moter/tranny mounts? someone give me some suggestions on what they think.
try slave cylinder or mastercylinder...is anything leaking?you might be getting blow- by so to speak.
i checked and there are no leaks
Take off at a higher RPM, i just installed a 3puck sprung disc, and if i dont take off at atleast 2500-3k, my car will shake and studder.. in any gear. this is what comes when you get a clutch meant for racing only.. heh, if the jumping gets worse as you take off at higher rpms, then theres something going on that has to be fixed. tell us what happens.
works fine when i engage the clutch at 2500 or higher.now i need to get some eurothane motor mounts because my old motor mount inserts are sooo bad.
