Journal bearing turbo options
Nicholas Andrus
78
3
Jun 21, 2015
Jacksonville, North Carolina
My build
6 bolt 2.4 G4CS engine, line bored and honed to 87mm, butchered 100mm crank shaft(21lb), GRP aluminum rods, ARP 2000 rod bolts, custom wiseco HD 10.5:1 gas ported Pistons(.019"/.024" ring gap, .006" PW clearance), kiggly girdle cleared for GRP rods, ARP main bolts, l19 head studs, OEM oil pump with straight cut pump gear, HKS head gasket. 6 bolt cylinder head, decked once, new valve seats, 5 angle valve job, ferrea valves, bronze guides, Supertech bee hive valve springs, titanium retainers, mild porting around the bowls. Forward facing OFH. Gsc s2 cams, 3g revised lifters, and rocker arms,
1000cc and 850 cc injectors right now, tial bov, vrsf intercooler, and mishimoto xline radiator, wally 450lph fuel pump ( might buy havent bought yet )
2g fuel rail, ecm link v3,
Magnus intake manifold, with a crazy throttle body (forget the mm but throttlebodies.com made it ) shepherd stage 3 trans, built tcase. Act 2900 clutch with the 6 puck plate. Or 8 i forget which. Fidanza light weight fly wheel (think i spelled that wrong)
I have a gt35r dual ball baring turbo with a custom exhaust manifold flanged for a tial wastegate/dump tube off the manifold. With information ive been told, rebuilding ball bearing turbos (garret) is both difficult an or extreamly expensive. Because the turbo only has 2k miles, if that, on it id prefer to get rid of it and find a replacement journal bearing.
not even similar flow rating as the gt35
just a turbo with around the 450-550 awhp range that's reliable etc and would go well with the rest of my build.
BEP S259 billet
HX35 or HX40 with the BEP T3 housing
FP DSM82 or DSM86,
FP3176
Any Turbonetics turbo with HP-66 (or more on the highside: HP-72) comp wheels paired with f1-62 or f1-68 turbines
Holsets require a little modification, but are about half (if not less than half) the cost of all the others listed and are very well proven.
Justin (JusMX) will have a lot more input on this than most. Try sending him a PM.
The failure rate of bb turbos is so low that its not a big of a deal as you think it is. My friend has been daily driving a 35r for over 10 years (+80,000 miles) at over 550whp and the turbo is still tight. I'd be more worried about your aluminum rods w/ ffofh and ptw clearance if the car is going to be a daily driver.
But as far as JB go, Holsets and borg warner turbos are the tanks that will take the abuse fairly inexpensive to rebuild as long as you dotn damage wheels and housings.
    • george bromwell
    • pma1123
    • Sdcryan1
