JE Piston ?s
SPYDERGSTTUNER
174
Feb 19, 2011
Rifle, Colorado
Ok so as some of you may know my stroker blew up a while back and i made a few threads asking for advice on what internals to use. After a few debates on selling the dsm, keeping her fwd, going stroker, 6 or 7 bolt etc. i finally decided to keep her, convert to awd, stay 2.0 and go with a 6 bolt block with a 7 bolt head. I have a bunch of spare parts of years of hoarding to be able to build 2-3 long blocks LOL. So the time has come for a rebuild. I looked through my stash of parts and what do you know i end up finding some Manley and Scat rods both bnib. I heard good and bad things about both brands but i think im gonna use the Manleys, I also bought a set of JE Assymetrical pistons which is where my dilemma begins. The pistons are an awesome piece, the machining is flawless and quality as always is top notch. Now, ive read in a few threads that JE's are known for piston slap but those threads are about 7 years old and i havent come across many if any new threads of anyone using the assymetrical slugs. So, i have a few questions to ask hopefully someone thats used/uses them can chime in on this:
JE pistons are 2618 with low silica so they will shrink and expand making them noisy on startup just like any 2618 piston will, but JE's recommendation is .0040 ptw. Does that sound right? I know the full round design requires a minimun of .0035 ptw but my machinist says they recommend those based on stock power levels. So is .0040 too tight if im aiming for 600+ awd hp?
I also read in a supra forum that assymetrical pistons arent a good idea for street use but the guy never explains why, is this true?
And laslty these pistons only weight 312 grams which is the lightest i have found besides the Mahles but those are 4032 and i had a bad experience with Mahles before, so this leads to my next question: i know the lighter the rotating assembly is the better for high and easy revs so my machinist suggests i use the ACL Race series berings since they are intended for better oiling at high rpms. He claims if i would have used heavier pistons he would have suggested a different bearing but with the light assembly those should be ok. But i read here in the forums that those bearings are too hard and may screw the crank up if the oil isnt changed very regularly. So what bearings do ya'll suggest for main and rods? ACL, King? Maybe Clevite?
By the way its a standard 6 bolt uncut, full weight polished crank. The Manleys are standard length 150mm with 22mm wristpins. The pistons are .020 8:5 if it matters. Thanx in advance
I have JE's full round ones. They were swain coated, and I believe .004 clearance. I ran it for 1000mi before I beat it. It runs great. Low leakdown, and low blowby. It is a little bit noisy when its cold, but its a race motor. The only difference with the asymmetrical pistons are that they have more skirt on the thrust face, where the engine needs it. The guys on supra forums are idiots, and don't have a clue. Any modern motorcycle has asymmetrical pistons and they turn shit out of them and they last forever.
ACL's I run rotella T 15W40, and I turn it 9500. I am also running a virgin n/t crank, that has been polished. Make sure to clean the oil galleys cause they hold lots and lots of grit. I ARP main studs now, but never had a problem with stock ones before. I also had the block decked to 0 deck height to utilize JE's quench pads. I also run oil squirters and got new ones for this engine.
I have read mixed views on it as well but never have seen real world results from people actually losing a bottom end due to not having one. But at the same time for some reason mitsubishi decided to put one in (2g 7 bolt) so there must have been a reason why it was added and still in their motors today. Hopefully some of the machine shops or guys who know some more about the girdle can chime in.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
