J-Pipe Leak, question
travislaw
389
8
Nov 4, 2005
Colorado Springs, Colorado
I was doing a boost leak test this morning and I am leaking air like a civ from where the J-Pipe meets the turbo. I have a new gasket in there and it is still leaking. What else can I use to help seal the leak? Is there any kind of RTV sealant or anything like that, that will work? I would greatly appreciate any advice. And yes I did a search.
Yeah, you can use gasket sealant to get that fixed. I usually put sealant around the BOV and a couple of other places, just to be sure. Never hurts.
Do you mean between the compressor housing and the j pipe? As for RTV, purchase the gray colored version.
Or you can go ahead and check out www.slowboyracing.com and purchase a gasket for the J Pipe.
Here is the link - http://www.slowboyracing.com/more.php?id=2077&
Good luck:rocks:
