1g j pipe question..
ludevtec93
192
Jul 15, 2004
oakland, California
i'm goin to be installing a 14b into my 2g next week and i was going to be using the 1g j pipe.. so i was wondering where does the nipple on the 1g j pipe go to?? thanks for the help...
yes it goes to the actuator but you can also put it to a MBC b4 you go to the aquator.
If you run it direct to the aquator you will hit 6-9 lb of boost is all
wut if i had the hose hooked from the actuator to the stock 2nd gen bcs... and cap off the nipple on the j pipe?? how many psi would i run?? would i run stock 2nd gen.. boost??
