2G It's time for coilovers...
YERFDOG
89
39
Feb 10, 2013
Bay Area, California
Hey everyone!
I would like some input on this setup for my GSX:
https://groundcontrolstore.com/coll...n-ground-control-koni-complete-suspension-kit
The car is only street driven (with occasional backroad cruising) so I'm looking for a "comfortable/tolerable" ride. Is this a good setup for that? I only plan to drop the car max 1.5", IF that. How about the price range? Are FEAL's worth the extra $300 or so? Overkill for my driving? Thanks!
Yeah those top mounts are not spherical so they will bind and cause spring issues when turning,
I second the feals, i myself use BC and they are good and they actually cost less then the GC units you listed,
Hey everyone!
Please keep in mind that Koni shocks are NOT rebuildable, meaning when they are blown they need to be thrown away and another set purchased. Also, looking at the price point of $1200, it will only be another $150 for a 441 kit which is rebuildable in house in CA with replacement parts readily available. Couple that with the spherical bearing top mounts and Swift springs, I believe this kit is one of the best on the market at this price point.
The main issue on 2g coilovers is the upper front mount. Very few coilover kits available for the 2g have a proper spherical mount, and without that, it's going to result in binding. The GC kit for the 1g is great, but the 1g front suspension is different than the 2g. Feal is one of the only kits that have a proper upper front mount.
How much does it typically cost to rebuild Feal shocks? My last quote to rebuild a rear Tein shock was $290, or... I could buy a new damper for $310... I asked them to ship it back and converted to Konis.
We charge $100 per corner to rebuild our road kits, and $125 per corner to rebuild the 451/460 rally kits.
When you order the coil overs from Feal, the checkout says " chassis not compatible with radial bearing"s so I am confused! The 2g's do not use MacPherson struts. So I ordered with out the bearings
The radial bearing goes in between the spring and collar on a MacPherson strut suspension. It's pointless on a wishbone setup because the shock doesn't turn with the wheels. The top mount on FEAL's is a spherical bearing.
