Its that time of year for going faster
toppertopper
444
May 14, 2009
edmonton, AB, Canada
The tracks have shut down until spring here ..Finally took the car out for my 1st run ever , tossed down a 14.7 on bald tires , spinning to 2nd 2.8 60's LOL ,..Also 1st time ever at the track i am hooked ... :sneaky:
I have been building for almost 3 years last year cost me 3 or 4 clutches since none would hold :ohdamn: .. This winter i am planing to build big before i blow or switch to awd ..
Mods plan would like some advice or info at some points pointed in the right direction
Mods over winter i am planing
HX35 with stock housing - so switching over to t3 manifold (have reading to do for the fitting t3 manifolds)
One issue i need someone to point me in the right direction is , the hx35 bep is the 5 bolt , i have seen some 5 bolt to 3" exhaust flanges ,..This will eliminate the 02 housing ,..Do i just get an 02 flange welded into that and still sim the 02 in dsmlink?
I need to install an aftermarket oil gauge ,before i can even get an idea of what kind of oil lines i need to use for the hx35...I do still have the balance shafts..
GAS AND INJECTORS?
plan is to go with race gas , i am in Canada and have to do some research to see what i have available close to me..
Injectors thinking of 1650's or bigger ?
fuel pump or pumps , dual 255 or something else?
TIRES
When it comes to this i see all the numbers and have no clue..I do know i want slicks in the front
i have seen for fwd 24.5 is better then 26" :confused: ..what size rims etc any help or pointing in the right direction would be helpfull..Also brands
Again i am fwd , non turbo trans , with act 2600 pp and act 6puck unsprung :sneaky: seeing how far it will go :thumb:
In the area of injectors/fuel pump, I'd say that 1650's are a bit excessive on race fuel. Now if you were running alcohol I could understand that big of injectors. I'd say 1000-1200cc would be plenty to handle an HX 35 with a stock rotating assembly(non stroker/hi compression). Also unless you're just planning a list of supporting mods for alcohol, a single 255 pump will be sufficient.
On a single re-wired walbro Im maxing my 1000s out on my stock t3 hx35 at 26 psi. I would go 1250s or slightly larger if I were you. Hell Ive been even looking at some high z 2150s just because the drivability is great with them. and it gives me a ton of room to spare since yes I do have goals but, what do we do when we meet them? Increase them!! I dont want to have to buy injectors for a 3rd time.
Yes i went with 550's , now have 750's ..I dont want to keep upgrading little by little , if i go with 1650's i will have plenty of room to upgrade i think the 2150's will be over kill for me atm ...
Any info on the other stuff i posted ? dual pumps or just a bigger pump , what about the slicks rims and tires??
