Issue with Greddy Profec B spec 2
b18cek
121
Aug 13, 2009
MI, Michigan
Hi,
I have a Greddy Profec B Spec2 that I just installed and I believe the unit is not sending power to activate the solenoid. I have ran power direct to the solenoid and it clicks (meaning it should work). Is there anyway to test the unit to make sure it is sending power to the solenoid?
Thanks in advance :)
Set the settings low and hook a meter to the output harness that goes to the solenoid to see if its getting power.
Also make sure your settings are right, Profec's are goofy.
