Issue with power
hurricanes71
149
Nov 9, 2011
clarksville, Tennessee
Ok I am still having the issue with my power windows not rolling up, my ac doesn't blow are at all the compressor comes on though, my interior lights don't work, the beeping when you open doors don't work. Everything else works. Now a little short story to what happened. I had some kind of short happen under my radio it cause a click noise and then you seen a little smoke come up, I pulled over and quickly went to check but I seen nothing and only smelt smoke. Ecu is fine I already checked. But I checked the fuses and nothing. Would a relay have to deal with all those problems? I would really like to get these garbage bags off my dam windows.
Did you check the fuse panel under the drivers side dash area and under-hood? It sounds like you could have blown a ground off something. You need to make sure those fuses are actually getting 12v to one side and the other is a chassis ground. Sounds like a couple hours with a continuity tester.
