Crashdot
- 2
- Jul 21, 2010
Honolulu,
Hawaii
Hi,
I have a 1999 Mitsubishi Eclipse GSX with a Greddy Profec B Spec II boost controller installed. The car is running normally; however sometimes when I start, I get a check engine light and code P1104, which it says is turbo wastegate solenoid. I am told that part is the same as the boost solenoid, and that this error means that the solenoid coil is being checked when the car starts and is returning a lower than expected voltage. Since my car has the Greddy boost solenoid, I'm not sure if the car's computer is checking that, or if the car is still checking the factory solenoid which could have failed over the years even though it is not in use(?).
Can anyone suggest what part I may need to replace?
Thanks!
Thanks!
