is this turbo a good choice ????
boostedinaz said:
No we just no better.
You are not making sure the wheels are perfectly round you are making sure they are weighted correctly, like wheel and tire balacing. Also, the speed the lathe turns at is not even going to come close to what the turbo spins at so I don't see how you plan and doing it correctly.
Ok, so if I had it sent out to get balanced how much would it cost??? and where would be the best place to have it done????
Do you have any heavy truck repair shops around? A lot of the bigger shops have the equipment for turbo balancing. I know around here, we have about 5 shops that can balance it while I wait. Generally, it cost from $50-100, depending on who does it. If you want to ship it out, fp will balance it and I think the charge is around $80.
yes, there are heavy duty truck shops around here but, I didn't know that they did that. I'll have to check that out. thanks :)
Actually sometimes the big rig truck shops can rebuild turbos and they usually do a great job. The kenworth shop around here rebuilds turbos and I think they even warranty the work. Those big trucks push a lot of boost and usually get a lot of miles out of them.
