Is this a Good Turbo
Iyaoyas
35
Oct 25, 2011
Brawley, California
I know this isn't the right place to post this but I cant post anywhere else, so I am sorry. I would like to know if this is a good turbo
GT45 T4/T66 PORTED SHROUD TURBO (TWIN SCROLL)
gt45 turbo charger 1.00ar
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 66.71 /84.20
Turbine wheel diameter : 63.56 /73.60
Exhaust trim: 1.00ar
Turbine flange type: t4 flange
Downpipe flange type : 3.25" v band flange
Cooling type: oil cooled only
Twin scroll turbine housing (quicker response then single exhaust outlet )
would love yall's input and thank you
A quick Google search reveals that this is a Godspeed turbo. Unless you want to replace it in less than 1,000 miles, no it's not a good choice. This horse has been beaten to death. Avoid cheap Chinese made turbos.:beatentodeath:
then what turbo would be a decent one for around 500-600 bucks(if there is one)? I don't mind looking stuff up but I have no idea what things are good for a turbo. I would like something that spools fast and can boost around 25-30 psi. I have heard a lot of things, like twin scroll, or ball bearing is better. I have very limited knowledge on this matter. Right now I have a cheap t3/t4 turbo and it sux. Thank you all in advance, and please be gentle. LOL
What you're giving us doesn't help much. What are your power goals? 25-30 psi on a 14b is vastly different from say a 20g( not the you really want a 14b that high). You need to take into account a compressor wheel's efficiency range. After a certain point, you'll only be blowing hot air. A turbo's flow rate is a much better indication of what you're looking for. You can find plenty of rebuilt MHI turbos for a price lower than $500 depending on size. Leaps and bounds more reliable than an eBay turbo for sure. Give us a proper goal you're looking to achieve horsepower wise and we can send you in the right direction. In the mean time, I HIGHLY suggest you use the vast amount of resources on this site to increase you knowledge on turbochargers and automobiles as a whole.:thumb:
My goals are if I can get 450 HP to the ground I will be happy ( no nitrous).
Then forget about my price range what would a good turbo be, I wouldn't want to max it out, with what I got. I would want room to grow with it. My upgrades all up current. I do all my own installs and rebuilds. It might not sound like it but I build all my own engines ( chevy 350's for a dirt track race car). I just don't know about forced induction upgrades.
Thank you Gravedigger for all your input, I will save up and get that one. with the porting. and thank you everyone else for your input
Ok so lets humor this.. you save up your ~$1100 + shipping for this 65lb/min DSM flanged turbo.
Have you researched what you need to support it? Or how to tune? Or considered what fuel you will be running to make that power and still have room to grow?
Putting together an NA SBC vs. a high-output turbo anything are night and day propositions.
