Is this real?
Judging by the item location and the seller's feedback score, you must be in the mood to lose $70.
it is not real i got my gf the same one awhile back. and it sucked made almost no sound save your money and get something better look in the classifieds and get something used if you dont want to spend alot
ebay bov's usually work pretty well. I assume your question was regarding whether it is a real hks unit, the answer is, most likely not. if you ever want to know if a deal is to good to be true look at the seller location, if it says singapore, china, beijing, pretty much anywhere apart from the us or the country the company is located in, chances are its a knock off. that being said, its probably a pretty decent bov. the ebay greddy knock offs work just fine and sound the same as the real greddy ones
Looks like the one i previously bought, only mine was silver.
Only way to tell is to open the diaphragm.
As long as it sounds good and holds boost then why complain.
I'm not sure if it's a real HKS, good chance it's not, but I know someone who is running the same one. He has been using it for about 6 months on his DD with zero problems and seems to function perfectly.
are you buying the adapter kit from HKS? or is it coming with one?
and if nothing else, measure the ID of your intake pipe, and then measure the OD of the adapter before you buy it.
that link is to a universal BOV, which it says at the bottom, does not come with a recirc kit or flange adapter. better find the vehicle specific one before you buy.
it sounds like the person you're buying that from has a recirc kit... i'd check that out. or just buy the BOV with it.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
