This is a real stumper
eclipsepunx
184
Feb 26, 2009
Sevierville, Tennessee
Ok i just replaced the engine in my 95 GS and finally got everything together so I try to start the car. Turns over perfectly but no fire. Checked battery, fuses, ignition coil, plugs, plug wires.(plugs are actually new but checked anyway) Then I tested the harness to the distributor and it has no power. The harness has been spliced and had some crimps on it and I never noticed that before but then again it use to work so I pulled the crimps off and checked the actual wires just to make sure it was the wires and not the plastic harness itself or just a loose connection. Anyway i'm stumped. I have power to everything else. How do I go about checking this to get power back to it? Any suggestions are appreciated.
There are grounds on the left side of the engine bay and on the right side, they are small and have 3 or 4 black wires coming off of them. On OBD II cars a loose or ineffective ground can cause crazy things to happen. I had a loose ground for the body controller on a neon and you could jiggle it and make the lights turn on and off, the windshield wipers wipe and other fun stuff. Check for both of those grounds and check their contacts, they gotta be clean with a metal to metal contact.
Oh no, I am not saying it is definitely anything till you tell me what definitely fixed it. LOL If you want definitely then I am gonna have to come over and check it out. Ha.
4.5 hours according to mapquest. If the Colt were running and I were in the mood for a cruise I'd be there to help but unfortunately the Colt is down and I gotta spend time fixing my stuff before I can drive to help others. Thanks for the feedback. Keep looking and trying things. Do you have an extra coil handy?
Just went and checked all grounds: tranny and near strut tower, 2 on fire wall, and the one you were talking about. all look good and getting same result. No extra coil. A guy at work was suggesting that but if I tested it and it tested good and i tested the wire and it isn't good would it really make a difference. I mean if I thought going and buying a new one would fire it up I would leave now and go get it.
Well it started. not sure why but I don't care. It started:D Exhaust manifold got hot instantly though and produced some smoke. Car has been sitting for a year though due to lack of funds. Could it be residue burning off? I don't know if it is overheating because the temp gauge on the dash isn't working. Is this something I should worry about?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
