is this a 1g?
drfinest1809
Jan 30, 2010
kssimmee, Florida
i need to no what you guys think cause i cant come to a clear cut answer is this a 1g head hope the pictures help...
http://i219.photobucket.com/albums/cc67/vrdubssat/Picture005-6.jpg
its a 1g it has a 1g thermostat housing you can tell because a 2g thermostat housing connects to the water pipe and the 1 gwater pipe goes stright to the lower radiator hose
Thermostat is definitely a 1G, the CAS is 1G and the block is a 2G. The head looks like a 1G from what I can tell but intake port pics would help.
actually they aret interchangable one is a 3 bolt pattern and the other is 4 bolt pattern unless i remember wrong... but thats why you have to go with a 6 bolt t-stat housing when doing a 6 bolt swap or a 1g head swap
and throw some rep points my way... if you dont mind LOL
the t-stat housings are not interchangeable as blackgst said, also if the outside studs were the exhaust manifold are all the same size then its a good chance its a 6-bolt head
This is right. They are NOT interchangable. My bad.
A 1g t-stat will go on a 2g head, but not the other way around. I have a 2g head on my six bolt right now, with a 1g t stat housing. But that is a 1g head, as it doesn't have the extra bolt hole for the 2g housing.
