IS the starter on a 1g the same as 2g???
Boxer132c
77
Dec 3, 2004
Fairview Heights, Illinois
Thats all I need to know because if not then I will have to buy a new one because I am doing a 6 bolt swap into my 2g
I think they are both the same. I was wondering the same thing when I put my starter on my 6-bolt, but I compared it to a 6-bolt one I found in the junkyard and they looked the same. I bolted my 2g one up and its fine. I'm assuming you are talking about a 4g63...not the N/T you have listed in your profile. I'm guessing there is a difference between 420a and 4g63.
yeah I am talking about the 4g63...So you did use the 1g starter on the 2g tranny and it worked??? or did you just think that they looked the same??
All 4G63's starters mount the same. The only difference throughout the years is a stronger starter used on 9/2/96- 4G63's. The later starter's are 1.4KW vs. 1.2KW.
