420A Is the 1g radiator the same size as a 2g radiator?
Gruff511
196
Mar 20, 2011
Fl, Florida
Does anybody know if a 1g radiator is the same size as the 2g radiator? I have a 420a and trying to get an aluminum radiator and since they dont make them i saw the 1g aluminum radiators and i think i could make it work but was wondering if it would fit in the same mounting points as the 2g. If its the same size but mounting points are off then thats not a problem
also a upper hole is in the middle on 2g, and on a 1g it is on the left, so you are running 420a, i think you should better go with 2g radiator
