Is the ceddy mods website down
Still have the speed density version?
I’ve got them. Here’s the links to the SD regular and big maps versions.
Non big maps
Big maps
Non big maps
Big maps
Will this work on either blackbox ecu? I heard that 98 and 99 may use 2 different roms for each year
I've flashed a 99gst ecu and a 98gsx ecu without issues. (I believe those are the only 2 part numbers. It doesnt matter if they are manual or automatic)
However you will need to follow the install procedure listed to properly install the ecu flash software. Basically you are installing ceddy mod files into the ecu flash files.
It can be intimidating, but gets easier as you play with the basic program
How to wire the GM 3 Bar map sensor ?
