Is something wrong with my AWD
97dark_angel
209
Jul 9, 2008
new paltz, New York
ok so im getting hit with a nor-eastern and its my winter with a dsm an awd, when i came home last night i got stock on top of small now bank, well big enough to get stuck on, the whole bottom of my car was filled with no you couldn't see under the car, when i tried to drive out of it only the 2 wheels on the passenger side were spinning not the ones that were on my side, MY question is is that normal or is some thing wrong? after i got out i took it for a drive and it was driving fine, some one please let me know what you think :confused: oh yeah its a 97 talon tsi
Its Normal, because you have Open differentials. If you did NOT have differentials you could NOT drive on the road or make turns.
My Jeep has LOCKING diffs So I can make it TRUE 4X4 where all 4 tires spin NO matter what. If I drove it like that on the road I would break my transfer case among other things.
When Turning each wheel travels a different distance through the turn, and that the inside wheels travel a shorter distance than the outside wheels. Since speed is equal to the distance traveled divided by the time it takes to go that distance, the wheels that travel a shorter distance travel at a lower speed. Also note that the front wheels travel a different distance than the rear wheels.
In your case you got HIGH CENTERED the snow is holding the car off the ground or keeping you from getting traction. All you can do is dig her out...or get it pulled out.
i thought 4 bolt rear ends had lsd?
LSD is still a differential. Its NOT a full LOCKED axle....It allows a Limited amount of slipage until it catches the other side and makes both wheels turn together.
Posi track is like having a locker but it opens when going around turns.
Then there is a SPOOL...That completely LOCKS the axle. Making it one solid axle.
For offroad use in Jeeps and other 4x4's alot of guys use Air lockers or electric lockers that way they can unlock them when getting back ON the road.
That's WHY I reccomend NOT welding your center diff unless you only use the car for straight line Drag Racing only. And maybe some Light street use, but its not good for the drive train components.
Wrong, it's just harder :D.
Have you EVER tried to make a full circle turn on concrete with ALL four axles soilid locked??? I doubt it. cause 99.9% of vehicles DO NOT have 4 locked axles unless you're driving an international harvester around town LOL :rolleyes:
Why do you think 100% of cars on the road have open diffs?
You might make a slight turn over a 100 ft radius but even that is HARSH on the drive train TRUST ME. Go Look up basic physics, Its a simple principal. The inner tires of the Turn travel SLOWER than the outer tires.
Some road vehicles like Jeep Rubicons, Ram Power Wagons, Land Rovers, Humvees Ect. have air lockers. But they are intended for offroad use ONLY. If you use these on the road they will void the warranty. This is because it can Damage EVERYTHING from the Tires to the tranny, transfer case, axles, U joints, driveshafts and more.
Did you maybe think I was talking about the center diff?? Cause that you can lock up and still turn...just not as easily as before at slow speeds.
thats odd, i did not know this.
As for my rear end it has full pos rear end with a lsd in the front...
I know because i love playing in the snow, and some similiar stuff happened to me.
I didn't know that they had different ones though.
Oh that would be awesome Ill have to check mine too. I thought only the 1g with 4bolt rear end had lsd stock.
im pretty sure even 1g with 3bolt axle rear end has rear lsd, i have one and it has the viscous label on it. i could be wrong but im pretty sure my eyes arent failing me. it was one of the buying points for me when i picked mine up a while back
I was speaking in general not specifically AWD. You have never driven with a RWD car with a spool before then... trust me it's surprisingly street friendly (at least when you have big tires).
I was talking about 4x4 or AWD. And yes I drive a RWD Jeep everyday with the rear locked with posilock, and it drives fine. The thing is the tires get worn and its harsh on the drive line. NOW if I locked the front and the rear all at the same time, it's virtually imposible to do any turning on concrete or on any surface with high traction.
If you are in heavy snow, Mud, dirt, sand or anything like that then its fine to have the front and rear locked together. The tires are able to SLIP in the mud.
If just the rear is locked you can still turn okay...but the tires are doing the sliping for you when you turn. The tire on the inside of the turn will always travel at a slower speed than the outer tire....so SOMETHING HAS GOT TO SLIP.
The OP's car is perfectly normal. It has a differential that allows the wheels to travel at different speeds around turns. This allows you to apply power to the wheel/s while turning and driving.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
