Is my radiator going bad?
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
Just got done installing new fuel injectors and new dash gauge unit. I was sitting in the car with the hood up and started it. After the car had been running for a few maybe 10mins. I noticed some white smoke coming from the hood so I went and took a look and I noticed it smelled like radiator fluid so I got to looking and this is what I found.
ALSO. My new gauge cluster oil pressure needle goes all the way to the top when the key is turned forward and car not started. And the oil light is on. When I start the car the needle slowly falls down all the way to the bottom and the oil light stays on until the needle has bottomed out.... :confused:
I have not tested the oil pressure gauge. It use to work when I bought the car and 1 day it suddenly stopped working. It always just sat at the bottom. But when I put this new gauge cluster in it went all the way to the top. I will need to look up how to test the gauge and the wiring of it.
Ah, I actually already ordered the Mishimoto Radiator.
But thanks!
Let me know how the radiator works out for you!
As far as the pressure gauge that sounds like a wiring problem, perhaps a shorted wire?
I am loving the radiator! I replaced all my radiator hoses as well. These two together have fixed my heater only getting warm to its damn hot just how I like it! My stock fans mounted right up to it. I did notice it does not have 4 mounting points for the fans like the oem one and no holes for the hard line that runs down at the bottom. I have a hands width of clearance next to my external wastegate. I have my MBC mounted to the top where a fan bolt goes.
As far as lowering temps I have seen no difference. But overall very pleased. No leaks and it looks purtay.
I am loving the radiator! I replaced all my radiator hoses as well. These two together have fixed my heater only getting warm to its damn hot just how I like it! My stock fans mounted right up to it. I did notice it does now have 4 mounting points for the fans like the oem one and no holes for the hard line that runs down at the bottom. I have a hands width of clearance next to my external wastegate. I have my MBC mounted to the top where a fan boot goes.
As far as lowering temps I have seen no difference. But overall very pleased. No leaks, I have beat and it looks purtay.
Awesome! Good to hear feedback. :)
Enjoy.
