Is my axle popped all the way in? (pics inside)
mini zilo
783
18
Jul 17, 2006
Chicago, Illinois
Alright, well here are some pics. There is a small gap between the trans case and the axle. Is there supposed to be? I can even see a little bit of the axle shaft on the inside of the case.
Is it all the way in?
I have a leak from this axle when moving, and I replaced the seal twice already using RTV.
In this second pic, look at the black space between the axle and trans case. That is not the seal, that is a small gap, and you can even see the axle shaft a little bit. Is that gap supposed to be that big?
Push it in with balls and it will fit tight, I had same problem with mine so I checked the end to see if there was space and what do you know there was a small space. After 10 mins of extreme pushing I got upset said F U and shoved it in there (kinda like throwing the pad when you lose in a game) and snap it went it.
there is a c-clip type ring on the end that has to sit in place use a rubber mallet on the axle and tap it in
    • george bromwell
    • pma1123
    • Sdcryan1
