is abs in the way
rod knock
Jul 13, 2005
charleston, South Carolina
hey guys i have a 92 tsi and I'm not sure if there are any known problems with the abs being in the way of aftermarket upper innercooler pipping
thanks for the help
My uicp is 2.5 inches around the ABS. Check out my gallery for a pic. It's a Dejon Tool pipe with the gm maf sensor, but you can get it without the maf I'm pretty sure.
I was also running 2.5 ic pipes when I had abs. Just make sure it is for an abs car and you will have no problems. I think you could probably get away with 3" ic pipes with abs but if you really need that much, you probably shouldnt have abs on the car anymore.
